Transmission life
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
How long does the transmission last?
I have been told that it lasts till about 100,000 miles and then needs rebuild.
Does it cause any problems using the shifter or sport mode all the time?
I was told that it can cause problems, which does not seem right if you it shifting with in the limits and not powering the car too much.
Pantherman2 (04-28-2015)
You have a ZF 5HP24. There is a known issue with the high pressure valve body in the tranny; the body scores, the piston hangs, and a pressure pulse overstresses the input clutch basket.
For what it's worth, BMWs and Audi with the same box have the same issues, so it's not Jag-specific.
Installing a rebuilt and updated valve body may forestall or head off the issue; but at that point, installing a reman with updated parts is not that expensive considering.
Yes there is an issue; but it's not life threatening in and of itself. It can be dealt with (as many, including me, have done). Now, whether investing 2500-3000 in a tranny (for the overhauled unit, rip and replace labor) is worth it in a car that's only worth 4-5K is a decision only you can make, though.
chatmanx
09-11-2015 07:17 PM
