Transmission Line
Transmission Line
Hi guys,
Have a leaky driver's side transmission line from the transmission to the radiator on my 99 VDP. I was just wondering if anyone could tell me if this is the pressure hose or return hose so that I can order a new one.
Have had it fixed 4 times now and it keeps springing a leak. Getting a little sick of being the little Dutch boy with his finger in the dyke. As always, input is appreciated.
Best,
David
Best,
David
The drivers side is the pressure side, the passenger side is the return from the cooler.
Attached is a shot of the transmission and lines.
If you keep having problems with the coolant line it is time to take a look at your motor mounts or transmission mount. Something is moving causing it to leak. That's assuming they were installed correctly and the mating surfaces are not damaged.
KidRock'n (11-19-2015)
