transmission oil pan needed or just filter
W5A580 Transmission drain & fill weblink
Hi
Here is the weblink to W5A580 Transmission drain & fill FAQ thread:
https://www.jaguarforums.com/forum/j...ons-faq-54992/
Go to post# 1 to download the PDF file.
Here is a PDF file on the W5A580 Transmission Fluid Pan removal & install (incudes Bolt Torque Specs).
2000 XJR Transmission Fluid Pan Gasket.pdf
Jim Lombardi
Jim Lombardi
Hi
Here is the Wa580 Transmission Fluid Pan Gasket and Transmission Fluid information I found on maxperformancecars forum thread (I updated the prices {retail and discount} and I provided the Supplier names and websites)
http://maxperformancecars.com/index.php/index.php?option=com_agora&task=topic&id=2794&Item id=159
Use Internet Explorer find function with "transmission fluid" as the search term, go to the 4th occurance of the search to find this posting.
Transmission Pan Gasket
Jaguar part number JLM20469
$32.80 $24.60 (JLM20469) Gaudin Jaguar parts
$14.50 $10.80 (1402710080) getmercedesparts.com
$14.50 $12.75 mercedesbenzgenuinep1.reachlocal.net
Transmission Fluid
Shell ATF 3403 - M115 (10 Liters)
Jaguar part number JLM20292
$37.70 $30.63 (Liter) (JLM20292) Gaudin Jaguar parts
$17.50 $13.13 (Liter) (001-989-68-03-10) getmercedesparts.com
$17.50 $15.75 /mercedesbenzgenuinep1.reachlocal.net
Note: These are Mercedes-Benz labeled bottles that are shipped/packaged to the Jag dealership in a Jag labeled box.
Jim Lombardi
Transmission Fluid
Jim Lombardi
Hi,Jim
Do you have any ideas how many quarts I need for the change,I dont have the dipstick also?
Hi
Transmission Fluid
Jim Lombardi
Transmission Fluid
Jim Lombardi
Hi
Looks like it takes 10 quarts to fill the transmission, torque converter and the cooling lines.
Here is a weblink to a thread on the XK8 & XKR forum about filling the MB WA580 transmission with fluid:
https://www.jaguarforums.com/forum/x...ush-easy-9760/
Go down to post# 7.
I thought it was 10 liters. It is still almost 10 quarts (9.46 quarts = 10 liters).
Jim Lombardi
Go down to post# 7.
Jim Lombardi
BrentGardner
28
04-26-2024 03:08 AM
xjrjag
10-27-2021 11:48 PM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
