Transmission question
99 xj8 vdp. Just dropped fluid and probably just saw the blackest fluid ever. It looked like motor oil. No metal or deposits came out. Could not find a hex bit small enough to remove the pan so guess I will have to change it again a mechanic shop. My question is this. This car had 106k miles on that fluid. It shifts fine but I am having this noise thst only occurs between 35 and 50 mph. When it does it the revs fluctuate and u can feel like its trying to search or the gear. If I accelerate it stops. If I let off it stops. If I get on it hard from stop it will not do it. Only normal driving and acceleration. I'm planning on having it change again with the filter this time but wanted to know if anything else could cause this noise???? Thanks.
The shifting problem could be the fluid & filter requiring changing-I'm not sure about the noise though. Are you certain it's the transmission & not the differential? Old diffs can sometimes whine, depending on whether they're transmitting power or on the overrun. Might be worth changing the diff oil as well...
aholbro1
08-05-2021 05:02 AM
