Transmission sound, normal?
I'm getting a sound idling in park that sounds like the solenoids cycling in the transmission. It's irregular at 4-10 second intervals, maybe longer at times. When it does the engine acts like its getting slightly loaded. I'm assuming that this isn't normal? 2002 XJR.
Received 1,797 Likes
It could be as simple as low or dirty fluid and thus the pickup filter being clogged. Do you have the trans fluid level spring cable? They are readily available on ebay (along with a new tube cap), but you must make sure you follow the instructions for proper fluid level check. Its not complicated, its explained why here.
I did actually have one for a Mercedes C43 AMG that I traded to a friend of mine. I'll have to grab another one. Thanks for the video link, that will save some digging.
I wish we could just buy a normal dip stick from Jag that would be the proper length that you could leave in the car.
I'll get the stuff to do a fluid / filter job and check the electrical connections for corrosion while I'm down there. I'm sure it needs it anyway. I was reading up on the conductor plate and those symptoms don't seem to fit. I was on the fence about getting an autoenginuity setup, this might necessitate it if the fluid level doesn't fix it. It seems like the solenoids are going berserk, cycling in and out for no reason in park.
Highhorse (09-20-2019)
Dell Gailey
08-23-2018 03:07 PM
