transmission woe's again
hi changed fluids back in February, I have driven over 4500 miles since. now my problem again is on cold start up Transmission will not shift to second gear unless I put it into sport mode .after transmission is warmed up no problems . it shifts like a dream, I changed to the updated valve when I changed fluid and filter. any thought's on what this problem might be thanks in advance jrb53
2002 xj8 x308
2002 xj8 x308
Received 1,813 Likes
You may want to review figures 5.1-5.3 of the electronics, http://www.jagrepair.com/images/Auto.../jagxj1998.pdf It sounds like you may have to get a diagnostic on it to see what isn't happening when cold. Motorcarman man be a good source for direction there.
jrb53 (06-18-2017)
