transmissions and fluid color
I bought a new to me 2003 XJR. The transmission fluid looks green! Alldata tells me it is supposed to be Shell ATF 3403 M115. It doesn't mention color (or colour for us up here in Canada).
Anyone have any knowledge on GREEN ATF?
Prior owner had it at the dealer with P1601 code TCM computer / memory fault. The dealer looked at the connections and couldn't find any faults. It shifts great, no lights on since I cleared them. Anyone have any prior P1601 transmission experience and / or problems?
The Mercedes-Benz 5G-Tronic (also called 722.6 or NAG1 (WA580)) is used in the 4.0 SC X308.
Many car manufacturers used the gearbox, Mercedes, Chrysler, Jaguar etc.
I have always seen the appropriate fluid color as RED.
Maybe someone used a fluid that meets the proper specs but is green??
IDK
bob
IDK
bob
Hmmm... I went to the Pentosin website:
http://www.pentosin.net/specsheets/Pentosin_ATF1.pdf
It describes it as amber and clear
Pentosin - Transmission Fluid
My previous XJR had red.
Regardless, I’m going to service it sooner than later.
If anyone else has green transmission fluid in their XJ, I’d love to hear from you!!!
IDK
bob
IDK
bob
I know others use "gold" coloured ZF fluid, but does anyone other than ZF use gold?
EDIT:
TransMax may be green in colour (no confirmation). Apparently CVT fluid is GEEN in hue. Trans could have mistakenly been filled with CVT Fluid.
Personally if it were me, I'd drain, get a new filter and replace with new fluid that you know what it is.
This is a MERCEDES gearbox we are discussing, NOT the ZF 5HP24.
bob
jazzwineman
03-08-2017 09:05 AM
sg18438
02-22-2017 09:35 PM
Sinister 1
07-03-2010 11:11 AM
hankycbr
10-09-2007 04:21 AM
