Trim settings
Hi all my car is running fine had to replace the coolant tank had not a split on the weld joint but on the engine side, all done
to check the trim what is the procedure by that I mean
should it be at a certain revs, should it be under load either by acceleration or up a hill, is it a certain speed.
what is the benchmark for testing if there is one?
jimmy
01-27-2010 09:00 AM
