Trouble after pot hole
Are you in GB? Bloody pot holes are causing problems all over. I hit one in my coach, and it actually tore some of the tread off the tyre! Thats a £200 tyre rendered useless, but we're in contact with the local council to try and reclaim the bill as it was they're shoddy road repairs that caused this, perhaps you could try a similar thing? Hope you get it fixed, S.
It is really easy to check the sensor like quadmaniac says. I would bet the sensor is ok, but you might have damaged the connecting the wires. If you don't have ramps, just take off the tire/wheel and the sensor is right there...the wire should be obvious. I would first ask if the error messages went away on restart....if so, don't do anything.
Jim
Chuck Schexnayder
33
10-24-2015 10:20 PM
