Trouble codes P0327,P1646, P0333 ?
Hi everyone! I`m new Jag owner XJ8 4,0 MY2001. On first day everything was ok but next morning starts with problems. I start the car, engine starts and dead next second. Battery was dead. I but on charger, car starts but some of cylinders don`t work. Restricted performance appear in the dashboard. I drive somehow to work. When i stop,then car has no power to take off. I replace battery, clear all trouble codes and car seems working normally. Drive 2-3 km. and same ting happened. No power gas pedal-no respons. I left car to parking place and come back later. Car starts and i drive back to workplace where i have diagnostic tool. Engine works but transmissoin was little strange. I made diagnostic and there was trouble codes:
P0327 -static-Knock sensor 1 (bank 1) control circuit (-)
P1646-static-Uncnown fault
P0327-sporadic-Knock sensor 1 (bank 1) control circuit (-)
P0333-sporadic-Knock sensor 2 (bank 2) Signal too large
P1000-sporadic- Unknown fault
P1646-sporadic- Unknown fault
P1647-sporadic- Unknown fault
Please give me advice what to check? Knock sensors?
Sorry my english, its not my home language
P1000 is not a trouble code. It shows that the ECU has not completed emission tests and will change to P1111 when tests are complete.
You may need to drive the car to get the restricted performance to clear, but that may still be displayed if there are Jaguar specific codes in the B or C series that you can't display with a generic code reader.
gene61jag
03-28-2016 05:45 PM
