Trouble Codes XJ8
Look up your codes on this chart then ask your questions.
Link http://www.jagrepair.com/images/Auto...7_ECM_2000.pdf
mara52,
I've moved your question from General Tech Help to X308 forum. This is the place to post questions about your model.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
In a nutshell you have a faulty coil pack on cylinder #2 (right hand A bank - USA passengers side, 2nd cylinder from front of engine).
The "0352" refers to the specific coil pack (035x is the code, where x is the cylinder number).
0302 = misfire cylinder #2
1316 / 1313 = injector misfire - you get this when a coil pack goes bad.
To double check :
- clear codes with your reader
- swap #1 and #2 coil packs around
- fire up and compare resulting codes. you should now have 0301 and 0351 which would confirm the coil pack.
AndyP
To double check :
AndyP
sparkenzap (01-15-2014)
Guy-Pierre Boucher
09-16-2015 05:55 PM
