Troubleshooting T605 Install
I've scoured just about every thread on bluetooth installs I could find in this forum. I'm using the Jim Roal bible, and I cannot seem to get my T605 powered up. I followed the wiring diagram verbatim,and can't seem to figure out what I'm doing wrong. Has anyone else run into this, or am I just the town idiot today?
Let me know if you have any pointers. Thanks!
I took a gander at Jim Roal's document, and although the wires are correct, the location of the fuses is different from what he specifies on a 2001.
For your car, make sure you have a good 5 Amp fuse in position #4 in the TRUNK fusebox and a good 5 amp fuse in position #22 of the TRUNK fusebox.
If not, add those fuses.
DIGITAL LCD VOLTMETER MULTIMETER CIRCUIT TESTER AMMETER AC DC METER OHM | eBay
Allan.
WhiteXKR gets the door prize...#22 fuse was blown in the trunk. She's installed and functional, but I do plan to redo the wiring, relocate the mic, and clean it up a bit. I'll hack the CD changer next with a switchable input, and then I should be good to go!
Thanks for the assist, everyone!
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
WhiteXKR (09-01-2013)
aholbro1
08-05-2021 05:02 AM
