Trunk?
I know there are hundred threads about it but I just completely went thru my wiring harness and even cut out 2 feet and replaced with longer wires to eliminate all bend areas and still no trunk release at dash or remote or growler button. Is there a fuse somewhere on this damn car thst controls that? I have no trunk lights but do have license plate lights. I have replaced micro switch and the plunger with working used parts. Nothing. There has to be a fuse for this!????? Anyone?
Are you checking for voltage at various points with a Volt Ohm Meter?
The VOM is your best friend. Radio Shack has pretty good ones for not
much. Make sure the bulb is good. I have a 12 volt power supply I use
to test used parts before installing them. That can save you a lot of
time when they are hard to access.
coastaljag98
Do you have the Vehicle Care Handbook for your 1998 XJ8?
If not, you can download all the Handbooks from the jagdocs.com website:
1998 MY XJ8 X308 Owners Manual Set [Jaguar XJ8 XJR X308]
All 8 of them for $5.58: 3.50 GB pounds (use currency button to change from GB pounds to US dollars).
Audio Systems - 30 Pages
Drivers Handbook - 117 Pages
In-Car Telephone handbook - 21 Pages
Maintenance Schedules - 8 Pages
Quick Guide - 4 Pages
Safety Advice Card - 2 Pages
Security system - 17 Pages
Vehicle Care - 93 Pages (it has the fusebox locations, and fuse numbers with info on what they protect).
I have no relationship with jagdocs.com - just suggesting a place on the internet where you can download the handbook pdf files at a reasonable price.
Jim Lombardi
Jim Lombardi
