Trunk/bonnet won't open
The trunk is the boot in English. If you have a remote, that will take it out of valet mode, but maybe the lock is not functioning.
It may be that you have two valet keys. Carefully compare the ends of the keys, the ignition key has an extra land machined there.
Pushing the valet button does not take it out of valet mode.
Try this approach: using the black key (not the green valet key), put the key in the key slot at the boot and turn the key. If that doesn't work, spray some WD40 in the key slot and work the key some more.
If that doesn't work search for the directions to open it using the under license plate hole that RJ mentioned above.
When you do get it open, check the wires going through the right boot/trunk lid hinge in a bundle. Common fault that one or more will break when flexing. Mine had the boot/trunk light wire break and that caused it to not be able to come out of valet mode. Strange but true. Lots in the archives about this problem.
kesslari
US Western
11-03-2015 08:43 AM
