Trunk latch removal/fix
I'm fixing my 2 trunk lights and in order to get to where I need to go , I have to remove the trunk latch. Here's my quandary... Latch pops and opens from the inside button, the key fob, and the button in the rear but won't open with the key! It does turn all the way however the latch doesn't release. Is it a quick fix? If so... any suggestions? Do I simply undo the 3 star bolts and move it to the side to remove the trim? Could use a diagram, had it off it appears the clips holding the arms are fine... How to I adjust the key one?
Thanks as always... Great forum!!!
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
