Trunk Light Dangling.
It is not supposed to be glued in. The light frame should have tabs on the small ends. The tabs are what is supposed to hold it in place. If the tabs are broken off then I would look for a new light at a junk yard. If they are still intact then the last person to work on tore the opening in the trunk liner. I have ccut a rectangular donut out of thin plastic and used it to reinforce the trunk liner opening from the backside.
If you want to just glue it back in and hope the bulb last as long as you have the car you will need to find an adhesive that will withstand high temp when the sun heats up the metal trunk lid. Somethiing like auto trim adhesive that they glue the plastic trim to the sheet metal.
King Charles (04-23-2017)
I glued the leather surround back with some 2 component stuff, worked well, just be sure to position it well before it dries.
If I remove the liner (had that to do that several times hunting a limit switch malfunction long time ago), I take care to loosen the liner a bit on one side, then get one hand in, and carefully push the fitting out, applying some pressure on the leather to prevent ripping again, same for installing.
Holding some 2 1/2 years by now.
omgimali (04-23-2017)
I think Jaguar originally used heat gun glue or something like that.
I think I scraped off the loose stuff, sounds logical, but can't remember I spent a very long time on it, as the glue is not visible after doing so (unless you do an improper job
