Trunk light switch works backwards
Discovered an odd issue last night partially closing my trunk lid while charging the battery. My trunk light cam on about a foot from being closed and stayed on the rest of the way down. When I open the lid, the light goes off. Any ideas? Sounds like an issue with the switch but what? It obviously works. Just works backwards. :shrugs:
Received 1,795 Likes
motorcarman (08-22-2021)
I did check and saw nothing that sent up a red flag there but I'll look again. Thinking it's more a switch issue tho.
Yeah, I despise it. My least favorite part of vehicle repair. Diagnosing is bad enough. Finding the actual problem even worse. And fixing it is often challenging as well.
I didn't fix it the best way I know but it should hold up fine. If not I'll do it the best way I know to and that's soldering the splice. Just a tough place to do it and I was too lazy to do it today after all the chasing it down.
There's not a chance in hell I could leave my ride running EPA lean, hot and neutered just to keep it under warranty.
I can't believe the performance minded here go thru all the trouble of cold air intakes and exhaust mods but leave the cats?!?! And y'all leave the breather routing hot, oily gases into your intakes?. What's up with this?
Ive got some good pics courtesy of DK Customs that details just how carboned up your combustion chamber/pistons get not to mention the effect it has on your intake charge.
Houses losing money?...I'm up over $200k from my purchase price now and when the housing crash happened in '08, I was still up then. They don't make more land, so it becomes more valuable, especially here in FL.
But, I wholeheartedly agree on the other items and why I won't buy new. Especially jewelry, furniture and automobiles/scooters. Well, I have to bite the bullet on jewelry, the girlfriend would know in an instant...damned female intuition...I think she can smell it.
OH!!...and flowers, yeah...don't get used flowers ....or does that go without saying? I tried the potpourri route, but it didn't fool her either.
...I tried to convince her they'd last longer.
...banned to the couch.
![Icon Stooge](https://www.jaguarforums.com/forum/images/smilies/icon_stooge.gif)
![Icon Couchhide](https://www.jaguarforums.com/forum/images/smilies/icon_couchhide.gif)
I actually bought the wife's engagement ring used. It was a really expensive ring that happened to have her birth stone as well as multiple diamonds. I'd a had a hard time buying it new back then. -
Gotta go with your gut tho.
But yeah, houses are an exception but I still never bought new. 2×@
I don't have repair bills except for parts and for the most part warranties are seldom used. Especially with good maintenance and dealing with things like cats and crankcase venting early on. Simply put they're not worth the you and engine pays for that warranty.
Obviously and for some unknown reason y'all either don't realize or don't care that those two cats are by far the most restrictive part of the exhaust system besides causing a significant amount of heat. Reducing heat is one of the best things you can do for the overall health of any engine.
Especially one that's been prone to failures of plastic parts gone brittle because of it.
Forget the added performance realized without them.
I'll run open loop so long as I can access and edit parameters in the ECM with a tuner and tuning program. I'm sure the ECM/O2 sensor thing is easily fixed one way or another.
Has anyone here done it?
You may find this of interest... https://www.jaguarforums.com/forum/j...project-52518/
Member like avos, XJR99 and Count Iblis are ones to review posts on mods. Addicted2boost and I have a system we are putting on mine shortly. I have to clean up some small issues before applying it.
