Trunk release
Received 9,010 Likes
Received 3,905 Likes
For those with the trunk issue, try these few checks.
First, access the electric solenoid and connect up a multimeter between the orange/red wire and chassis ground (or the black wire on the solenoid). Now, attempt to open the trunk. Did you see the multimeter jump up to 12 VDC (11 VDC or more) for a second or so? If yes, then you have a bad solenoid. If no, then your problem lies with either the wiring between the solenoid or the security module (repeat the check at the security module and if you get 12 VDC there, bad wire, if no 12 VDC, then you have a bad module).
Because you have lost the ability to open the trunk with both the key fob and the pushbutton inside the car, we can rule out the trunk button. Also, because you are not complaining about not being able to add gas to the car, I know that the security module is getting power.
if you need more help, let me know.
fredd60 (03-15-2013)
do your numberplate lights work ?
does your trunk light work ?
check the wiring that follows the right-side hiunge when the trunk is open .
bet you a beer your wiring has broken
does the release button on lid work ?
Finbarr1975
09-16-2023 02:52 PM
