Trying to fix norma heater hose connector on 2003 JAGUAR XJ8
Old 03-14-2021 | 11:00 PM
newoldjag's Avatar
Lightbulb Trying to fix norma heater hose connector on 2003 JAGUAR XJ8
So I have attached images of the 5 way pipe, where one end has broken off from underneath the throttle body. I'm wondering if I can attempt to fix the issue without replacing the entire 5 way heater hose system. Is there a workaround where I could possibly connect the gap with a spare 3/4 inner diameter hose? Or of a different measurement?
general location of coolant hose
norma pipe connection on end of 5 way hose
intake valve where the norma pipe broke off from
intake valve where the norma pipe broke off from (zoomed in)
Old 03-14-2021 | 11:16 PM
Highhorse's Avatar
Looks like someone has already been patching things with that hose clamp.
The fix is in the eye of the beholder, like in this thread.... https://www.jaguarforums.com/forum/x...leaking-94360/
Old 03-15-2021 | 03:40 PM
newoldjag's Avatar
what is the metal part that the hose fits on to called? in the 3rd picture? the other threads i've seen dont seem to have that same valve
Old 03-15-2021 | 07:30 PM
newoldjag's Avatar
https://www.ebay.com/itm/JAGUAR-OEM-...A/161588957479
nvm found it, for those in the future, here is the part. hopefully it works and doesnt leak when i get it
Old 03-15-2021 | 07:31 PM
newoldjag's Avatar
NNE3944BA
MussieRon
16
04-07-2020 08:49 PM
skinnypuppy_22
03-10-2018 10:51 AM
vsol
05-10-2017 01:05 PM
4litre
09-27-2016 08:04 AM
kitty
07-19-2013 09:24 AM
Quick Reply: Trying to fix norma heater hose connector on 2003 JAGUAR XJ8
