Turn signal issues - not the bulb
Ok, So my right side turn signal stopped working last week. Replaced the bulb, but it was still not working. I tried moving the steering column up and down, back and forth while the rt turn signal was active, but no change.
I am going to dig deeper into the steering column wiring connectors under the dash, but wanted to know if there are any control modules that could be the problem. I learned when my right brake light failed that it is never as simple as a burned out bulb.
I will clean the contacts. That is a great idea and thanks to both of your replies. You never know with the electrical stuff in these cars
I was getting the same thing - faster turn signal sound, but no light flashing. Turned out there was a crack in the signal light housing, water got in and grounded out/corroded the bulb socket. Disassembled, cleaned, sprayed with DeOxit (contact cleaner) and sealed the crack with Krazy Glue until I could get a replacement. Which I never did, because its still working fine a year later...
99xk8guy
06-05-2023 06:28 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
