Turn Signal Silence
generally it's the speaker given up the ghost...you can buy from radioshack similar or hack a cheap radio up for one. Or it could be a wiring fault, i.e. solder points on the speaker, I'd be inclined to suspect the former as it went intermittent then died.
You'll need to remove the lower steering wheel shroud to access the speaker and wires, a couple of pozi screws hold it in place.
Hope that helps.
Hope that helps.
Richard_gib
09-12-2015 07:08 PM
