twin cooling fan motor rebuild
Complete good used fan/ cowl assy for $150, if that helps.
Coventry west rebuilds alot of stuff, Motorcars might do these as well, and there is someplace called Jaguar Services near Chicago that used to do blower motors and such. No idea if any of them are any good, I'm just name-dropping.
Guest
Posts: n/a
I have had 0 luck findings anyone who wanted to rebuild these motors. I believe motor cars sells just 1 motor for like $150. The motor casing isn't really designed to be disasembled (lots of metal tabs that have to be bent).
I pulled mine apart, the brushes were completley worn down after much research I found some replacement brushes. I should have it put back together in a couple weeks. I bought a full shroud assembly off ebay to get me back up and running.
The back spindle i believe is just mounted in a brass bearing (no *****). The front one looks to be a regular bearing. You would need to remove the t-bar that engages with the fan blade as well as a snap ring in order to get the bearing out..
What leads you to believe the nearing is bad?
Hope this helps
Hope this helps
abonano
25
09-25-2015 10:43 AM
