U1261 code, may have found some answers
I have that U1261 code that seems to defy us. Well I may have found some answers to it as this has been a subject many times in the past without many answers to it. I also found a tool to help with the code as a n OB2 scanner will show it but that is it. Instead of me going into detail, I am posting what I have found along with a couple of videos on the tool and its use. As I search out more I will post what I found.
https://www.google.com/search?q=Stan...hrome&ie=UTF-8
https://www.autoserviceworld.com/car...work-problems/
https://www.searchautoparts.com/moto...icate?page=0,1
https://www.google.com/search?q=DLC+...hrome&ie=UTF-8
This should keep you all busy for a bit and as said before if i come across more I will post it here
Highhorse (06-13-2020)
I attach files that I have on generic fault codes, many of which should also be applicable to Jaguars. The links at codes connect to a website which, in most cases, provides detailed info on the code selected. However, in the case of U1261, it only states "SCP (J1850) Single Ended (-) Circuit Failure" and no other details are provided.
Don B (06-15-2020)
Received 13,379 Likes
Hi daverb,
I am attaching the Network DTC Summaries for the 2003 AJ27. According to the manual, here are the definition and possible causes of U1261:
I am also attaching the Electrical Guide, which contains the wiring schematics for the SCP network.
Regarding the OBDII/CAN DLC breakout box, there are far less expensive options than the OTC-branded one. Mine looks and functions like the OTC but cost significantly less.
Cheers,
Don
Cheers,
Don
The following 4 users liked this post by Don B:
Don B (06-15-2020)
Hi daverb,
Cheers,
Don
Cheers,
Don
