unlock and lock buttons dont work on keyless entry,among other problems
Guest
Posts: n/a
first my unlock and lock wont work on my remote but the trunk release button does any clues? and recently my alarm started going off for no reason,also when i got in the car today my driver side do was closed, i was driving and it said driver door opened,and all the interior lights started flickering,its sound like it might bea short,i already checked all thefuses and there all good,any help would be appreciated
RE: unlock and lock buttons dont work on keyless entry,among other problems
Whats up Chad. More Chads are always good....haha.
For starters, on BMWs I've heard of low batteries causing strange electrical gremlins, one of them being the alarm going off for no reason. I'm not familiar with Jaguar's wiring though.
The "door open" and lights issue is your door microswitch failing, that I'm pretty certain on. Just a small switch on each door that tells the car which doors are open and shut.
Received 2,194 Likes
Chad, As i said in the pm, its in the latch assembly, pull the door panel, remove the rods that attach to it, the electricasl connector, and the bottom bolt for the window rail to move it out of the way. Now remove the 3 torx bolts by the latch assembly on the side of the door around the latch and then work the old latch assembly out and install the new one
1 Post
door open indicator
I have the same problem - dash says driver door open. So the remote lock won't work - just makes a long beep sound when I press the button. Door will lock with the key - makes the same protesting long beep sound but locks car. It makes sense that it is the micro switch. I called the local Jag dealer (in Halifax, Nova Scotia Canada) - tells me I need to replace the whole door latch and that it is $500!!! Looked on-line and found a door switch for $26. Is this all I need to buy?
Thanks,
Trevor
Thanks,
Trevor
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
Marque
08-27-2015 11:53 AM
