Unlocking with a key
If I unlock the car with a key, either the valet key or the regular key, the windows start to roll down immediately. I understand that the windows should roll down after a short delay while holding the key in the rotated position. On my car, there is no delay. The windows immediately attempt to roll down when the key is turned. Any ideas if this can be adjusted? Thank you!
Do a "hard reset," reprogram your windows and try again.
Procedure is in the stickies at the top of the page or you can search for it.
Hard reset: Basically you remove the battery cables and touch them together (disconnected from the battery!) for 10 seconds and re-connect.
Vector
Vector
