Update transmission woe's
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
So drained fluid removed filter, then valve body checked out with no problems. installed new updated pressure valve. neat trick putting O rings in freezer to shrink O rings. installed valve body, new filter again with new gasket. refilled using same fluid which only had about 25 miles on it. ran through gears topped off fluid. took it for a drive now everything is great shifts through all gears. the only thing I can think of was a bad filter. If you are going to change fluid and filter make sure you get a good filter not a cheap one like I did the first time, it does not pay spend the extra $10 dollars . as far as the upgraded pressure valve well worth the money extremely smooth shifting and feels like a new transmission. thanks for all the help and input jrb53
![Icon Razz](https://www.jaguarforums.com/forum/images/smilies/icon_razz.gif)
BobRoy (01-22-2017)
My suspicion is something was amiss with the valve body install that corrected itself on the second go around. Fixed by "removed and reinstalled same" I doubt there's a bad batch of filters out there, they are pretty simplistic in design/function where the valve body is very complex and tolerates no leakage, misalignment etc.
