upgrade audio system?
Hi Wishin
It has been discussed here before. Seems possible by buying the required parts.
https://www.jaguarforums.com/forum/s...ghlight=satnav
You should consider if its worth it as the functionality of the factory sat nav is limited, but as others correctly stated, it does work ok.
If you are talking about upgrading to the large colour touchscreen as seen in the X350 (US MY '04 and up) I've never seen this done
If you want to add a proper aftermarket sat nav system, it can be done, but is quite intrusive, ie
https://www.jaguarforums.com/forum/s...ghlight=double
Guest
Posts: n/a
audio upgrade
hi sarc, thanks for replying i will look on websites. if to costly i might leave it till i can afford a newer model with all singing and dancing gadgets. last jag i owned was 28yrs ago 2.8L 1973 so i shouldnt be to concerned with my audio system, certainly come a long way to the old 8 track i had balancing on the crome city dash board of my jag.
42Ajd
12-30-2015 09:45 AM
FS[MidAtlantic]: 1997 XJ6 VDP - Very RARE Black on Black
42Ajd
09-21-2015 07:37 PM
