Upgraded supercharger upper pulleys/porting
Old 01-13-2019, 03:13 AM
anduha's Avatar
Just a quick question. I have been considering a 1.5 lb pulley which should yield 13.1 PSI and 13000 RPM max speed. Does this mean with no other mods due to heat increase and increased SC hp requirements the car would actually be making LESS peak power? They claim a 25 hp increase in the midrange which seems like more usable power around town at the cost of overall performance. Not sure if it is worth it.
Old 01-13-2019, 08:34 AM
Sean B's Avatar
Received 1,357 Likes on 1,068 Posts
The engine management is designed to retard ignition when hot. If you live somewhere warm and tend to kick its head in everywhere then prior planning like an upgraded intercooler pump and larger radiator will sort this out.
literally thousands of these engines have larger crank/smaller nose pulleys - I've ran both upper and lower together without overheating - it's down to ambient temps.
Regarding the added power, I would say you access it earlier, meaning the torque comes in earlier because the SC is spinning up quicker - you'll notice it from a standing start. You only start to get gains with intake mods and exhaust on the dyno.
Old 01-13-2019, 12:57 PM
anduha's Avatar
I drive the car gingerly except for the random on ramp blast and live in a moderate climate so from what you are saying doesn't look like an issue. I'm not looking for a track monster just a little more low rev shove. Thanks for the info!
GGabriel
11-22-2018 03:53 AM
zoozth
10-01-2015 06:09 PM
dieseldoc
09-28-2015 01:17 PM
BlacXJRcat
09-25-2015 06:43 PM
Quick Reply: Upgraded supercharger upper pulleys/porting
