upper chain tensioners
Here are the part numbers for the tensioners:
2W9Z6K254BA
2W9Z6K254CA
and the bolts (you will need 4): W500301S300
Call your local Ford part supplier and give them the above part numbers. They are the same as Jaguar but for much less.Don't forget the bolts, as the metal tensioners require shorter bolt.
Also, get the valve cover gaskets. Some recommend aftermarket, but I'd go OEM as its something that you will not replace often (we all hope).
Check this forum for "zip tie method". You will find pics and helpful recommendations. Good luck.
2W9Z6K254BA
2W9Z6K254CA
jamies xj8l (02-14-2013)
mikiep
12-20-2019 07:37 PM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
