upper shock mount bushing failure
Edit: I believe I found it on Parts Geek. It said "EuroSpare" and that threw me off, but examining the pictures I can see the part says Meyle.
http://www.partsgeek.com/catalog/200...ock_mount.html
The URO parts have a bad reputation --- many if not all of the rubber parts come from india and don't hold up. The failures are all over the MB forums -- for a wide variety of parts. MB owners tend to keep the cars for along time -- so the experiences is over 6 months.
It would be helpful for those who have installed the URO parts to report back.
I would pay the extra and get the Meyle part -- Meyle may mention "Germany" -- but they are also resellers ... it's most likely coming from China.
Interesting comments about the aftermarket repair kits. I was thinking of going down this route even though I'd have to order from the US. The small saving when shipping is added dosen't seem to outweigh the hassle of fitting them and the apparent unreliability of the material used.
I just don't know why Jaguar felt the need to completely redesign this part, the poly foam used does fail over time but for my old X300 you could just buty the foam bushes and swap out quite cheaply, like the radiator mounting bushes which seem to have been replaced on the X308 with tougher rubber parts. I can only think they were preparing for the adaptive dampers fitted on later models...?
Neither the Uro nor the Meyle units are repair kits. These are brand new shock mounts (no hammer, no press); just remove the old and put on the new ones. Makes an incredible difference; like new ride and dead quiet compared to the overhaul kits . . .
My overhauled mounts were always quiet in the summer, but as soon as the temp dropped below 50*F, hammered their *** off.
#28
Jhartz - I was refering to your insightful comments regarding the "overhaul" kits (from Welsh and the like). I can obtain the full replacement part here in the Uk for around £42 ($60...?) a side, but I'm not sure of the actual manufacturer. Mine are still intact but look tired and may need replacing in the next year.....
Jhartz (02-22-2016)
#30
3timejag (01-12-2018)
#32
#33
Do a search on this forum: Old Mike (wonder whatever happened to him?) did a photo segment on the steps back in 13 or 14 (just don't bother with the BFH approach if you are buying the replacement Uro or Mehle parts). An easy job, left side is five minutes longer since you need to loosen the power steering reservoir to get at a couple of bolts. Be careful where you place the jack (to raise and lower the shock into the mount). A really easy job.
Faintly remember a YouTube video as well. Also a photo group from some guy in Central Florida who pointed out that the URO and Mehle units were available, instead of the ridiculously priced OEM from Jaaaaguar.
3timejag (01-13-2018)
#34
FS[SouthWest]: Complete SU Carb set for a MK2
61_mk2
01-05-2016 12:39 PM
