Upper shock nut
Upper shock nut
Should I be able to turn the upper shock nut (the big gold one) by hand? I have an ‘02 XJR with only 56k on it and it has a clunk going over bumps. I replaced the shocks with factory CATS ones, but this nut seems loose to me, and I can’t seem to tighten it any further. Any ideas?
If it's still clunking, it's probably the shock bumper in the mount. It will look OK but they will thrash about when driving and make that clunking sound. I know from experience after changing a lot of parts on my car until I finally changed the mount and years of clunking were eliminated.
I know about the internal hex, I've held that to get the external nut as tight as it will go. There is still about 1/4" of threads visible in the nut when it is tight. I can't tell if the shock just won't come up anymore or what. I'm hoping someone with the same car can verify if what is happening in the video I attached with the post is normal or not.
See my pic. About 1/8” of thread visible. The whole bushing assembly is tight and cannot be moved like yours. You will note the additional washer. This was not a necessity but just something left over from when I was chasing a suspension rattle. Mine are factory top mounts. Maybe some aftermarket mounts have less thickness in which case the shaft thread could be bottoming out. Something is stopping the bush from being in compression. Maybe do some dimensional checks.
Cookj61 (08-21-2022)
Yes!!! I remember I had a slight issue with this on my CATS equipped 2003 a few years back when installing new shocks. Jack up the car a bit to take the pressure off, loosen the top nut, and move the shock shaft around until it moves freely through the mount sleeve. It's a tight fit so it needs to go in just right.
Don’t mean to hijack but can anyone confirm the thread direction of the top nut for cats dampers?
Yesterday I was attempting to replace my upper shock bushings, I stripped the internal hex of the shock shaft while trying to turn the nut counterclockwise to loosen. I did the rear bushings and didn’t have any issues with the top nut. I suppose I can try to grab the shaft with vice grips but looks like I’m buying new front shocks if that doesn’t work.
Thank you @XJR-100. I was pretty sure it’s standard thread but thought I’d ask.
I did take a 9mm hex and filed it down to about 8.4mm so it just barely fit inside the nut and lightly hammered into the stripped hex but after using an 18” breaker on the nut (ccw) the hex stripped again.
Very frustrating since the shocks are (were) perfectly fine. I used penetrating oil and let it sit for an hour, tried shocking with an impact, and heated the nut with a torch but it’s like the nut and shock are welded together.
Guess I’ll have to cut off and buy new cats shocks. Ouch… so much for an easy Sunday job replacing the top bushings. The rears came apart so easily.
Hi Cookj61,
Compare the nuts that came with your new Bilsteins with the nuts from your old ones. You may find that the original nuts are taller and will thread down farther onto the shock shaft, solving your problem.
I don't know why Bilstein supplies shorter nuts with the new shocks, but I've had the same problem.
Cheers,
Don
Cheers,
Don
RaceDiagnostics
07-07-2012 05:24 PM
