Urethane shock bushings
Received 1,797 Likes
These folks don't do the shocks, but the control arms... https://www.powerflexusa.com/shop/ca...1997-2003-1985
But these guys do... https://www.carid.com/2000-jaguar-xj...ings-hardware/
Have you replaced your upper tower bushings? Because if your lower are toast, most evidently your tops are also.
The rubber lower bushings are cheap and last a while.. Second the upper bushings check too. Though urethane uppers tend to squeak/rattle esp in the cold, best to just get a foam oem-style assembly. Also if your rubber lower bushings are worn, and you're not in some heavily salted/corrosive area, it may be worth thinking about replacement shocks (they come with new bushings as well)
Jon89
16
01-18-2017 02:10 PM
