Urgent, Will this radiator fit?
As far as direct fit, I say no since it says 4.2 and 3.0, but I'd contact the seller since I don't see any dimensions. It should be about 27.5"L x 23.5"H x 2.5"D ...from top left to hose center line roughly 7.5" and right side top to hose center line roughly 5".
Your going to want to make sure it fits because you have no clearance up to the hood for modifications and all your attachments with a SC need to be properly placed since they are formed to fit and you need to clear your belts and pulleys.
It would have been nice if he'd of taken more than one pic instead of using 5 of the same thing.
I've dealt w/ this guy a couple of times w/ no issue.
https://www.ebay.com/itm/Jaguar-XJ8-...3/123727863494
Highhorse (07-11-2019)
Better contact him first as that part # search comes up w/ XKR, even though he listed it as XJR.
I linked you to a good used unit above.
X308 radiators used by XJ8/XJR (replaced my leaking XJR rad with one from a xj8-exactly the same) are the same or current PN: MNC4190AH
X308 Radiators Do Not mount the same as X100 or X350 radiators. X308 radiators do not have pins, rather a rounded side that is sandwiched from by radiator top mount panel. the MJB4190BC rad above is not going to fit, highly doubtful the original posts listed rad will either.
While not drop in, you can make anything fit......
