Using evap smoke machine on x308
Received 1,798 Likes
Thanks. I just hooked up smoke machine to the evap port and found my leak. The metal pipe between the two carbon canisters had a pinhole leak. Can not even see the pinhole, just the smoke exiting. Put some JBWeld on there and seems to be fine.
Also had smoke coming from the little piece off of the right side vapor canister filter that looks like a little hat with holes in the bottom. I am thinking that this should be venting, unless it has a failed one way valve. However, give the amount of smoke it would have likely shown as a large evap leak code rather than small leak.
The smoke machine is an OTC LeakTamer that I picked up cheap on evilbay. Not a tool you use a lot but has come in handy a few times, Found the leak on Jag and recently an oddball intake leak on my Porsche 914, also great for tracking AC system leaks.
Thanks again.
Thanks again.
