valet mode issue 2000 xj8
motorcarman (12-16-2016)
You need to use the black key and open the trunk. The valet should then cancel. If it doesn't cancel then reopen the trunk and do a hard reset. Remove the negative cable and touch it to the positive. It will restore all modules to default settings.
The idle revs will be a little high for a few minutes as the ECM relearns the TSP position. You might also have to reset the windows.
The ONLY way that I am aware of to cancel the VALET MODE is to have the BOOT OPEN recognized by the car.
You might get the same result by replacing the BPM or SLCM????
I forget which module controls the function.
bob
