Valve adjustment "how to" factory service manual
Doing a valve adjustment on car is an absolute mind numbing experience unless you have the exact Jaguar service tool. And even then it looks difficult. I did mine when I had the heads off due to a blown head gasket. It was still a ton of time, patience (was all gone half way thru the process) and a coffee can full of bucket shims (not kidding) that somehow didn't have some of which I needed. If I ever have the heads off again, I'm splurging and having the reputable machine shop doing for me.
What you need right now is just your clearances. Turn the crankshaft in a clockwise direction untIl the extended part of the lobes are up on the valves you want to check. Take a feeler gague and then find the clearance between camshaft and the cam bucket. Make a note of the clearance of each. I usally mark them I 1-8 and E1-8 starting from the front of the engine. Save these notes because it will make it easier for your adjustments later.
Do yourself a favor and REMOVE the exhaust cam even if you have the cam lifter depression tool. The intake cam cannot be removed without the front of the engine disassembled.
I borrowed the tool from the tool room when I worked at the Jag dealer and I just gave up and removed the exhaust cam to speed up the repair.
bob
bob
Don B (09-01-2016)
Don B (09-01-2016)
You have to devise a way to depress the outer edge of the lifter 'bucket' to gain clearance so the shim can be pulled from between the cam and lifter.
The tool 'catches' the edge of the lifter and the shim is free to slide out. Please ensure that the piston is lower in the cylinder so that the valve does NOT contact the piston!!!!!
bob
bob
Don B (09-01-2016)
So I've checked the valve clearences and I don't think the car is in need of a valve adjustment, it seems that I've got three stuck valves. Now to pull the heads.
Here are the results of the valve clearances:
Driver's side:
I1: 0.008-0.010 E1: 0.010-0.012
I2: 0.008-0.010 E2: 0.010-0.012
I3: 0.008-0.010 E3: 0.010-0.012
I4: 0.008-0.010 E4: 0.010-0.012
I5: 0.008-0.010 E5: 0.010-0.012
I6: 0.008-0.010 E6: 0.010-0.012
I7: 0.008-0.010 E7: 0.010-0.012
I8: 0.079-0.080 E8: 0.008-0.010
Pass Side:
I4: 0.008-0.010 E4: 0.008-0.010
I8: 0.089-0.090 E8: 0.083-0.084
Driver's side:
Pass Side:
sempaipaul
06-30-2007 06:49 AM
