Valve body solenoid voltage
So, I am curious, today I hooked my car up to a scanner to check trans oil pressure and other trans info, well I noticed the voltage on the solenoids was all over the place, I am curious to know what they should be at to work properly?
Are they all located in the lower forward valve body? Could this have anything to do with the PRV issues these cars experience?
Thanks guys!
Thanks guys!
Received 1,813 Likes
Wow, getting kinda deep, perhaps Plums, Don or another more knowledgeable member can better answer (I hope so)?
But this... http://www.jagrepair.com/images/Auto...ansmission.pdf ...and http://www.jagrepair.com/images/Auto...P2400.PDF...is all I found and it doesn't have readout specs. I would say if it was an issue you would be throwing a DTC to reference as in the second link.
FS[Europe]: 4.2 Throttle body Bored out to 78mm
avos
04-12-2016 05:01 AM
Lagonia
04-10-2016 04:58 PM
