Valve cover
Received 1,800 Likes
Your best bet would be a cam cover from a 2000-2003 4.0 Supercharged Engine because you don't have VVT. The Normally Aspirated engines have the VVT actuator protruding though the cover with a seal installed.
The earlier covers (AJ26) will work but the gaskets are different and are not as common (They are orange for one side and grey for the other) and are thicker. The spark plug well seals are also different (one is in pairs instead of individual).
Do some research and make sure you get a match to what you have.
bob
bob
The earlier covers AJ26) will work but the gaskets are different and are not as common (They are orange for one side and grey for the other) and are thicker. The spark plug well seals are also different (one is in pairs instead of individual).
bob
bob
jaguarVP96
04-22-2016 02:21 AM
