Valve cover gasket?
Did you change 100% of the gaskets and seals?? I just did this Friday it literally took me longer to replace all the gaskts and seals off the car then it did for me to pull the valve covers off then to change all the valve cover seals and bolt seals and my covers the two inner bolts (under the coil cover) were the worst offender of bad bolt seals, literally filled the spark plug hole with oil. For it to come out of your AC vents you must be gettting a lot of underhood smoke, I assume you are smelling it burning or seeing it outside as well??
xjrjag
09-27-2015 01:53 AM
1964Daimler
09-09-2015 11:20 AM
