valve cover gasket oil leaking on manifold
need help with changing my valve cover gasket on my 2000 jaguar xjr, theres a leak coming from the valve cover I replaced it with new seals and grommets and gasket but my breather hose or I think it's called crankcase ventilation at the hose part not the actual crankcase ventilation broke in half would that cause the valve cover to leak ?
giandanielxk8
06-03-2019 07:26 AM
