vdp 2001 dtc p1646.
RE: vdp 2001 dtc p1646.
My scanner book says the code is A bank upstream O2 sensor. Possible Causes:
O2 sensor heater failure
O2 sensor sensing circuit short circuited to ground or high voltage
O2 sensor sensing circuit open
ECM failure
It seems ECM failure is the last one on a lot of codes.
I would check the O2 wiring and maybe take the connector apart and clean it real good with electrical contact cleaner.
Blaze
ECM failure
Blaze
zigzewel
09-29-2015 12:42 PM
