VDP Warnings galore
VDP Warnings galore
My dad's VDP was running just fine yesterday, although admitedly with ABS, ACS and TC warning lights/messages in amber. I drove it for about 4 hours around the motorways in the island without a single hiccup. I did drive the car in sport with the ocassional j-gate. However, I drove her smooth and gently most of the way.
Today upon startup it's displaying engine failsafe and gearbox fault as well. I was thinking it might be the battery.
Any thoughts?
Any thoughts?
And the odds were with me. I checked the battery. The poles weren't properly fastened. I tightened them up real good and started the car up again. It was a success. No more gearbox failure or engine failsafe warnings. I didn't even have to swap with my XK8's battery to test it out.
Now, I'm thinking about how to clean the ABS, ASC and traction control sensors. How do I proceed?
I did not understand. Are the lights on as soon as the car starts, or after it moves a short distance? After a hard reset, does the car have to move before the lights come on?
I unplugged a wheel sensor once to see what happened, and the lights came on immediately, which makes sense with a open circuit. But a poor solder connection to the abs pump only caused an error after the car moved 100'. Turning the ignition off reset the error light until the car moved again.
Yep, being on a CAN-bus electrical system means that when voltage drops, everything goes wonky and you get a ton of faults. When my battery was failing, the first symptoms were the ABS/TCS faults, then it started shifting wrong, then it started running wrong.
But as for getting the bolt out, your best bet is a good long soak with penetrating oil and then try drilling it and an easy-out. You may just have to drill it.
giandanielxk8 (05-31-2014)
abs warning
I was not sure what the case would be with the XJ8. My XJ6 would only display the warning light after driving a short distance, and my Autoenginuity program will not interface with the ECU, apparently too early a model.
No Ross, I mean the Autoenginuity doesn't even recognize the OBD system. All it says is no codes reported or something like that.
At least with my XK8 it finds the modules, although it reports no connection to the instrument pack. It also won't do any on board diagnostics. The XK8 is a Oct 96 build, and Autoenginuity warned that it might not be able to interface as well as with later modules. I wish I could make some use of it to chase the cruise control failure that occurs periodically.
Meanwhile, I think I have highjacked giandaniels thread, for which I apologize.
the Alternator is bad as well. amazon Denso for $185 and get a new big battery and all your lights will go out...
Any thoughts?
Any thoughts?
giandanielxk8 (06-05-2014)
5 of the last 6 x308's I own had the ABS/Traction control on and they all went out after I replaced the Alternator and Battery...Should be a sticky at this point on this Forum, to replace your Alternator/Battery before posting LOL>>>>>>>>>>>>>>>>>>>>>>
goges
10-05-2015 04:53 PM
