vette71
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hi all! Just pulled a code p1646 linear O2 sensor control chip (bank 1) from my 2000 vdp. Does anyone know if this is jaguar manufacturers code for O2 sensors in bank 1 or am I looking for some kind of control chip for bank 1. If anyone can help I would appreciate it as I am lost on this one.
My info says a "P1646 - Fault Description: Fuel pump 2 (SC) relay malfunction". That sounds a little flakey, because your car isn't supercharged and the non-supercharged cars only have 1 fuel pump - I believe. "Possible Causes: Fuel pump relay 2 failure, Fuel pump relay 2 to ECM circuit fault, Fuel pump relay 2 coil power supply open circuit, ECM ground circuit fault (relay coil drive)". Maybe I'm barking up the wrong tree, but that's what it has in my Alldata ref.
