Vibration comes and goes at 75-80 mph (Not in the steering wheel)
Hey everyone, so I have a minor issue. When driving at or above 75mph and precisely at 78 mph, I get a noticeable vibration throughout the car's body. It is most felt when you put your hand on the dash and through your butt from the seat. The trick is that it sometimes comes and goes for no particular reason. (example: driving 78mph on cruise control and the vibration comes, then seemingly like magic it will go away....and then comeback) Now, before you ask, the tires and wheels are new (it did this before the new tires and wheels); I have switched the wheels front to back with no change, and to top it off there is absolutely no vibration coming from the steering wheel. As mentioned above, the vibration is only felt through the seat and dash. I think the center support bearing, u-joints, or something else in the driveline is to blame but I'm curious what others might think.
I have had the car up and took a peak at the driveshaft and nothing seems to be amiss besides what seems to be a "ring" of oil and and dirt near the back of the center support bearing which might be from the U-joints. Also the car has 74k miles
Any help would be appreciated
I'm more inclined to think the oil ring near the support bearing is an indicator of the issue. You may have some wear / gauling in a U joint, but it hasn't completely chewed it up yet. the extra slop could be the caused of the oil ring as it would overheat from the increased friction and also push the seal slightly out of place, causing said oil ring. Or possibly the support bearing could be having a similar wear issue. But I'm still thinking the U joint. Just a couple of thoughts. Hope it helps.
Jack
Jack
Check tires
These vibrations can be caused by a plethora of cirumstances, sometimes a combination of them occur:
- Tires/rims out of balance
- Differential output shafts (greasing mine did help)
- Flex couplings (hardy disc) x 2
- Prop shaft center bearing
- Wheel bearings
- Prop shaft out of balance
- Hub bearings rear axle (2 per side) on the hub carrier (when these are rusted, they push the wheel out of alignment)
- Anything loose in the suspension. Be it worn out or just loose
- Wheel bearings
Jack
Jack
