Vibration, engine mount or fuel trims?
The car vibrates slightly on idle in park or neutral, nothing massive but you can feel a trembling going through the car. It only does it when stood still and goes away when driving or revving the car. No front end knocks can be heard at anytime.
Could this be the engine mounts, the reason I ask is I also have high LT and ST fuel trims and I understand this can cause a similar thing. However the car always shakes when stood still whether I'm in open or close loop, when cold and engine idle revs are higher it can be felt more than with a hot engine and lower idle engine revs. Both idling speeds are smooth and constant.
Any ideas??
Any ideas??
Dont think Ive checked this area, at least it doesnt sound familiar. The throttle body rubber ring does feel a bit suspect, but increase pressure down on intake elbow onto the throttle body makes no difference to the trims, and it does seem to fit snugg round the intake and throttle body. Plus I would have thought above all the Jag specailist would have found this.
Performance is good, very good since I fitted nameless Cats and custom exhaust.
No codes of course, I do however have a minor oil leak, not sure if this is engine or gearbox, so small I've never looked as of yet.
Charlene n John
09-28-2015 06:01 AM
