Vibration(pulsating) at highway speeds
After going over 50mph... there is a vibration that is consistent and pulsating depending on the increase in speed.
Maybe you could try repositioning the drive shaft.
Usually when dropping the shaft it is marked to reinstall in the same position. That is impossible when the diff is replaced.
Did the whole shaft come out? Was the centre support bearing disturbed?
If you account for the possible 4 positions at the front and 3 positions at the rear, that is 12 possible positions to try.![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
But, in this case, you will only need to account for the possibilities at the driveshaft to differential companion flange.
Jaguar Forums Editor
Jaguar Press release
09-25-2015 11:58 AM
60, car, differential, highway, jaguar, mph, princemarko, pulsating, pulsing, rear, shudder, speed, speeds, vibration, vibrations
