I have a 98 XJR that has a vinyl pinstripe. I'm not sure if this is a factory option or a dealer installed option. Its a double pinstripe that wraps around the sides of the car and the back but not the front. On the doors it has a small break where a detailed jaguar leaper appears. The stripe is white in color.
The stripe is cracking from age and i would like to replace it. Does anyone know where i could source a new pinstripe or if this was a dealer option?
You can contact your local Jag dealer (I did) and ask them whom they use for body repair and take it to them. I have to change a right front fender (PO banged up and covered up) and I have a replacement, same color code, but the pinstripe is located differently.
