Wacky Window Drops When Starting
Passenger window has started acting wacky. When I turn the key to the farthest position in the ignition, before cranking (or as I pass this position) the passenger window lowers. Whether I crank and start the car or leave the key in the pre-crank position or remove it from the ignition, the window will not go up with the drivers swicth or the switch on the pass door. I can hear the switch clicking inside the door when I push the buttons.
After about 1 minute either switch will work to raise the window whether the car is running or not. I can replicate this over and over. The battery has 13 volts cold and gets about 14.3 volts from alternator when running, and I have done a hard reset which hasn't changed anything.
I haven't pulled the door panel off yet, any ideas??
