Warm air blowing in RH floorboard
Well I felt way up under the dash while it was blowing hot air and it isnt coming from the floor duct, but somewhere around the top of the heater case. So, is this a common problem that you can tell me about or am I just going to have to find it when I pull the heater case? Does pulling the heater case require pulling the dash? Thanks
-Rob
-Rob
DING DING DING! I found the problem. On the RH side under the hood there is a cover that bolts down over the ECM. This cover is missing on my car. After lifting the computer, I can see the passenger side floorboard of the car. I covered the hole with duct tape and all of my problems have gone away. I am now on the hunt for an ECM cover so I can get this duct tape out of here. Thanks for all the replies. I am so happy to have gotten to the bottom of this. My A/C also seems to be working great after eliminating the hot underhood air from entering the cabin. Now I just need to do my lower ball joints and my RH wheel bearing.
-Rob
-Rob
Malihide
04-02-2016 04:05 PM
