Water Leaking Onto Drivers Side Floor Board
First time I've run my 98 XJR through the car wash since I bought it. Heard a trickling noise all of a sudden, looked around and then saw a pool of soapy water on the drivers side floor board. Funny thing is, afterwards I looked up under the dash and didn't see any water anywhere. Stuck my hand up high toward the firewall, above the brake pedal area and felt behind some wiring / insulation and it was wet.
Would this indicate the windshield leaking or?
Regarding my interior leak. I sprayed water on the windshield and under the cowl area and noticed the water was just pooling up under the cowl and not draining. There's one drain hole on the plastic cover underneath the wiper motor. I found a rubber flap covering the hole...I assume it is supposed to be there and allow for the water to drain slowly? Not sure...well, I grabbed that and it just came out altogether and the water dumped out. I'm fine with not having it in there.
However, I found the leak was coming from a split seam in the panel under the cowl area. Right where the two metal panels join. There is supposed to be a sealant there that had split, allowing the water to leak into the car. I sealed the split, and will see if the leak is taken care of tomorrow after everything is cured up.
And I have not checked to see if the repair worked or not. Going to go spray it down here in a bit.
99xk8guy
06-05-2023 06:28 AM
